Tienda | Foros | Blogs | EN |
bathroom extractor connection
Hello everyone, I have to install a bathroom extractor but the possible connections to the outside are a skylight and a ventilation shaft of the blind well that comes from the ground floor, is it possible to connect it to the latter without the problem of smells coming back?
Hi. I would not advise you as you would be sucking out the odors or mixing them. The ideal is a new pipe where to place it at the end or just a hole in the wall that comes out. regards
