me sirve esta tarjeta de video?
hace 5 días
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Pentium D 930
Codename Presler
Specification Intel(R) Pentium(R) D CPU 3.00GHz
Package (platform ID) Socket 775 LGA (0x2)
CPUID F.6.4
Extended CPUID F.6
Core Stepping C1
Technology 65 nm
Core Speed 2992.3 MHz
Multiplier x Bus Speed 15.0 x 199.5 MHz
Rated Bus speed 798.0 MHz
Stock frequency 3000 MHz
Instructions sets MMX, SSE, SSE2, SSE3, EM64T, VT-x
L1 Data cache 2 x 16 KBytes, 8-way set associative, 64-byte line size
Trace cache 2 x 12 Kuops, 8-way set associative
L2 cache 2 x 2048 KBytes, 8-way set associative, 64-byte line size
FID/VID Control yes
FID range 14.0x - 15.0x
VID range 1.116 V - 1.308 V
Chipset
Northbridge Intel i945P rev. 00
Southbridge Intel 82801GB (ICH7/R) rev. A1
Graphic Interface PCI-Express
PCI-E Link Width x1
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 2 GBytes
Channels Single
Memory Frequency 332.5 MHz (3:5)
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 13
Bank Cycle Time (tRC) 21
MCHBAR I/O Base address 0x0FEDA0000
MCHBAR I/O Size 4096
Memory SPD
DIMM # 1
SMBus address 0x51
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) STT (7F7F7F7F7F7F34000000)
Size 2048 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number SUPERTALENT02
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 3.0-3-3-8-11 @ 200 MHz
JEDEC #2 4.0-4-4-10-14 @ 266 MHz
JEDEC #3 5.0-5-5-15-21 @ 400 MHz
Tarjeta de video la cual quiero añadirle a esa PC: Geforce 9400 GT (r-vga150915h) gf9400gt 1024mb ddr2 hdmi fan.
Esta es el modleo de mi fuente de poder https://www.serverworlds.com/dell-k8956 ... s-375ab-a/
hace 5 días
En principio sin problemas. La pruebas con la misma fuente. Si funciona bien adelante.
hace 5 días
Es una tarjeta vieja pero valida, el tema es que se queda desactualizada.
Depende para que la quieras, el cpu , creo que es un Pentium D 930.
Aca tenes un video con tu procesador y una placa parecida.
Pentium D 3.00 GHZ, 1.5 GBs of RAM, nVidia geForce 9600 GSO 512 1.5 GB, 1TB Hitachi 7200 RPM HDD
